Home » Audio » Source » Buying a turntable
Re: Buying a turntable [message #12680 is a reply to message #12678] Thu, 08 December 2005 07:05 Go to previous messageGo to previous message
The Mk 2 has the best reputation but in my opinion as long as they all have the same arm then they are pretty equal. I have not studied all the models but that info should be available.
Cartridges; well if you have the ortofon which is a good cartridge then that should be fine. Remmember as long as the cartridge is compatible with the arm then it is a matter of taste in terms of sound quality.
Above you ask about moving coils and I admitt I am partial to them. They have a frequency response that reaches up into the 30k range so some who own SS equipment don't like the rising high end. Also you must have a step-up device to properly drive the phono stage and that adds to the cost. The MC carts track at higher level; usually around 2.5 grams.
There are high output MC's like the Ortofon MC 5 that I like and they are reasonably priced and track at a lower force. Regarding high tracking force;
Many think that means greater record wear but studies done in the 80's disproved that notion.
In the interest of brevity let me say this; for the Technics and your needs there are many very good carts out there of the Moving Magnet type. If you have a 100$ to spend then the Shure M97 ED is a very good choice; nice and rounded with good tracking and smooth presentation.
Other than that I prefer to stay away from Grado's for this table. I would suggest the Ortofon is a good choice. Their 540 model is an old favorite. If you have more money; then the Audionote Iq series is the best MM out there that I can see. They sound like moving coils without the hassle of step-up devices.
If you want to go extreme with it; then the Denon DL 103/Audio Technica 150/ Denon 601 these are great sounding carts that will run you around 250$ and properly set-up in the Technics will equal almost anything within reason.
I use an old Empire MC Gold at the moment. When that is done I have a Fidelity Research waiting in the wings.
Hope this helps; cartridge recommendations are simple really; providing you have a well engineered deck then most of the good brands that are medium compliant and reasonable output will sound fine. While they may be different from each other; they will still play nice music.
Since it is hard to audition these things it is my experience that the best course is to go with what you know; that being the Ortofon and since you like that cart, maybe just stick with their line since it is very musical and good sounding. They offer a range in price from 90$ up to 2500$ for a cart. so that means plenty of choices.
If you decide on a MC; the Denon's are available for 250$, as is the excellent and rare Audio Techinica 150ml which BTW is a MM cart.
Previous Topic: A needle for my old MicroDD1
Next Topic: surface noise/static only in left speaker channel
Current Time: Tue Nov 03 06:38:37 CST 2026
