Home » Audio » Source » Turntable hum
Re: Turntable hum [message #12615 is a reply to message #12614] Thu, 17 November 2005 18:24 Go to previous messageGo to previous message
Anonymous is currently offline  Anonymous
There MIGHT be a problem with the cartridge, but I doubt it. I had another cartridge (Ortofon OM 10) and my turntable produced just the same noise. In fact, it does so even if the cartridge is not connected.
I tried running my computer audio output and my tape player through the preamp, and it worked well. (They do not need that, but I did it for the sake of testing).
Just a few minutes ago I thought about connecting the grounding wire to a power outlet's grounding post, but for that I need to modify the power and the grounding wires of my turntable. I can cut off the original plug, buy a 3-pin plug and safely connect the power wires and the grounding wire to it, after which it will be easy to use. Do you think it will work?
Thanks.
Previous Topic: Help needed with a turntable purchase
Next Topic: Automatic Reject rejects too soon. Fisher MT-6630
Current Time: Wed Oct 21 20:43:01 CDT 2026
