Home » Audio » Source » Grados,ortophons,shures and AR turntable hum
Re: Grados,ortophons,shures and AR turntable hum [message #12463 is a reply to message #12461] Tue, 16 August 2005 17:15 Go to previous messageGo to previous message
Say Russell; do you have both ground wires connected? and if so how does it do if you remove one of them? Have you tried swapping the positive leads on the cartridge pins? And hum is usually simple in Turntables; so are all the wires tight and have continuity? I have had that happen before, loose wire.
Previous Topic: HELP with my Acoustic Research XA!
Next Topic: ID of LP's
Current Time: Thu Nov 05 13:55:06 CST 2026
