Home » Audio » Source » HELP with my Acoustic Research XA!
Re: HELP with my Acoustic Research XA! [message #12437 is a reply to message #12436] Mon, 08 August 2005 16:06 Go to previous messageGo to previous message
If you remove the bottom cover you will find there is a solder terminal where the spider thin strands of wire from the cartridge/arm connect to the output cable. They are very fragile!
There is neutral and hot just like at the cartridge pins for each channel plus a separate ground. I recall then being color-coded like the cartridge but I'm not certain.You may have a partial short to ground on the bad channel so resoldering those leads might help.
In any case, further help is available fron DDarch at Vinyl Nirvana or The Analog Dept
Previous Topic: Ping Hurdy-Gurdy
Next Topic: Grados,ortophons,shures and AR turntable hum
Current Time: Thu Nov 05 13:54:37 CST 2026
