Home » Audio » Source » connect tuner from receiver to integrated amp
Re: connect tuner from receiver to integrated amp [message #12424 is a reply to message #12423] Sun, 07 August 2005 06:41 Go to previous messageGo to previous message
What is a denon DRA-385RD? If it is a tuner, run a pair of interconnects from the tuners out to the in of the pre or integrated. If it is a receiver, set its switching as if you were going to record fm except instead of plugging into your tape deck, plug it in an input on the pre. Its the same signal, it will just be going into your pre ( or integrated) input instead of the tape deck. Is this what you mean?
Russellc
Previous Topic: Straight vs. S-shaped Tonearms
Next Topic: AR mods: Merrill sub chassis
Current Time: Thu Nov 05 18:05:32 CST 2026
