Home » Audio » Source » Shure V 15Vxmr initial disappointment. Help needed!
Re: Shure V 15Vxmr initial disappointment. Help needed! [message #12337 is a reply to message #12336] Thu, 14 July 2005 07:24 Go to previous messageGo to previous message
Interesting problem. I don't feel the Shure is a natural match for the SME but it should work.
The MC1 is a very bright cartridge, maybe you are used to that and the Shure needs some time to acclimate.
If you are experienced, and it sounds like you are; then I would suspect either a set-up problem or a stylus problem. Possibly the SRA is off or mis-aligned. Did you use a record to check the setting of the cartridge? I would try that first to make absolutely sure the set-up is accurate.
Does the cartridge mis-track on inner grooves at all?
Does your pre-amp have an option to change the cartridge loading? That could be an issue. Let us know.
Previous Topic: See warning in digital section about Sony CDs
Next Topic: Dust Covers
Current Time: Thu Nov 05 23:51:02 CST 2026
