Home » Audio » Source » anti-skating problem
Re: anti-skating problem [message #12327 is a reply to message #12326] Mon, 11 July 2005 11:10 Go to previous messageGo to previous message
Mr Vinyl is currently offline  Mr Vinyl
VTF stands for Vertical Tracking Force. It's the amount of weight that the cartridge sits on the record. It's important to get this correct because if it is not correct you can ruin your records, your needle or both. See the link below for a Shure Gauge. Each cartridge has a specific range that it must be set too. Order the Shure gauge, find out what the tracking force is for your cartridge and use the gauge to make sure it is correct. I wouldn't play any records until you set this correctly.
Hope this helps.
Mr Vinyl
Previous Topic: as the record plays my strobe doesnt show a steady mark
Next Topic: Best Vintage Table
Current Time: Sun Oct 25 01:03:35 CDT 2026
