Home » Audio » Source » 1200mk2 pitch control re-set?
Re: 1200mk2 pitch control re-set? [message #12292 is a reply to message #12291] Tue, 28 June 2005 07:41 Go to previous messageGo to previous message
Where did you tweak the control; on VR 301/201 or VR302? You may have to balance the pitch control with the brake adjustment. Let us know how it was tweaked and we may be able to help. The Pitch Control Gain Adjustment is probably where you are misadjusted. Do you have a schematic? It is just a simple pot but it affects all three settings.
If you can get to the three adjustments it should be simple. Are you good with mechanics?
Previous Topic: Need help understanding my Museatex BIDAT manual (Ed Meitner)
Next Topic: Record cleaning product
Current Time: Fri Nov 06 00:24:15 CST 2026
