Home » Audio » Source » HELP! my counterweight broke off
Re: HELP! my counterweight broke off [message #12060 is a reply to message #12053] Fri, 08 April 2005 20:25 Go to previous messageGo to previous message
Dominic is currently offline  Dominic
It is almost impossible to find another counterweight.
Ok here's what you may want to do.
Measure the apporximate weight you need, probably around 10 ounces or so. measure the diameter of your tone arm (1/4 inch). It will be larger at the other side of the fulcrum (1/3 inch).
Go down to Home Depot or Lowes and find several big bolts which will not cost you much. Try these out. When you can get the stylus to balance just barely above the record then that is zero grams. tap a hole in the bolt (1/16 or so) and put in a set screw.
Carefully adjust the counterweight inward so that it causes the stylus to deflect 1/16 inch which should be about 2 grams. you are set.
Previous Topic: Tracking Force
Next Topic: Walker Valid Points and New Plastic barrier for turntable Pics.
Current Time: Sun Oct 25 21:07:44 CDT 2026
