Home » Audio » Source » Systemdek 2 bearing
Re: Systemdek 2 bearing [message #11973 is a reply to message #11961] Sat, 05 March 2005 09:44 Go to previous messageGo to previous message
kyle is currently offline  kyle
One other thing you should try. Remove the spindle and take the ball bearing off of the end. These usually have a flat spot from years of abrasion. Rotate it so that the flat area is not on the bottom. This gives you a new bearing point and the bottom of the bearing well is usually flat or at least has marginal wear.
Previous Topic: Turntable thrust bearing (replacement) alternative
Next Topic: LAB 80
Current Time: Fri Nov 06 00:44:40 CST 2026
