Home » Audio » Source » Turntable thrust bearing (replacement) alternative
Re: Turntable thrust bearing (replacement) alternative [message #11968 is a reply to message #11729] Wed, 02 March 2005 07:12 Go to previous message
DanR is currently offline  DanR
Original Message -----
To:
Sent: Thursday, February 10, 2005 8:14 AM
Subject: Re: Turntable thrust bearing (replacement) alternative
> Dale;
> I am really happy that the solution worked and appreciate knowing that you
> have succeeded in getting the TT up and running properly.
> I, too, had the loss-of-bearing problem for many years and finally decided
to
> take action.
> It's interesting to note the the Lab-80 was the first TT (at least from
> Garrard) that used the slick-plastic Delrin in a trip-mechanism. It was
used
> because it is light-weight and a low-friction material that would allow
the
> trip action to work with minimal drag on the unit.
> It was to your good fortune that you had access to the punch set. Cutting
> the washers out using the X-acto knife was not fun.
> Let me know from time to time how the fix is working -- it should perform
> well for many years ...
> Regards,
> DanR.
Previous Topic: Do I need a Phono pre-amp box???
Next Topic: Systemdek 2 bearing
Current Time: Fri Nov 06 00:15:41 CST 2026
