Home » Audio » Source » Systemdek 2 bearing
Re: Systemdek 2 bearing [message #11963 is a reply to message #11961] Wed, 23 February 2005 06:40 Go to previous messageGo to previous message
You have a problem. Bad bearings are a wash. Most good guys who restore turntables use a sleeve of teflon in the bearing well. First; how did you determine there is bearing rumble, with a stethoscope?
Second you need to find out if they used an off the shelf bearing assembly or one that was custom made. Wherever they sourced the original bearing; that place may still be around. Try some research on the Vinyl Engine site, they should have the info you need. There could be a replacement since there are lots of those tables in use. Since that was an English product I bet Len Gregory has knowledge of it. Try the Cartridge Man site.
There are no quick fix's for bad bearings.
Let us know.
Previous Topic: Turntable thrust bearing (replacement) alternative
Next Topic: LAB 80
Current Time: Fri Nov 06 00:45:01 CST 2026
