Home » Audio » Source » Turntable thrust bearing (replacement) alternative
Re: Turntable thrust bearing (replacement) alternative [message #11936 is a reply to message #11729] Tue, 15 February 2005 20:33 Go to previous messageGo to previous message
Daave is currently offline  Daave
Have you ever had the problem with the Lab-80 where neither the "Auto" nor the "manual" paddle switches will stay on?? Nothing seems bent-most of the old visible grease has been cleaned off from the various levers and arms on the underside of the turntable. I am the original owner of this turntable, it always ran very well, packed it away-now neither of the power switches will not stay in the "on" position. Any ideas on some adjustment-particularly with the main cam- that would cause the two power levers to not stay on?? Any advice would be greatly appreciated.
Where did you order the teflon to make the bearings??
Sounds like a great solution to improving the LAB-80.
Thanks-Cheers-Dave
Previous Topic: Do I need a Phono pre-amp box???
Next Topic: Systemdek 2 bearing
Current Time: Fri Nov 06 00:15:45 CST 2026
