Home » Audio » Source » Pink Triangle LPT repair?
Re: Pink Triangle LPT repair? [message #11927 is a reply to message #11926] Sat, 12 February 2005 07:03 Go to previous messageGo to previous message
Thats a tough one. Could be the motor is seized from wear. How old is the unit? What happened during the move, is it possible in the process of unpacking the TT the motor shaft was banged?
Why do you suspect the power supply? When you say you moved house did you move out of country?
Is that a DC or AC supply?
Depending upon how handy with tools you are I would suggest consulting a tech. There are a number of issues possible with this and it may need a pro to fix and since that is a nice table I would be carefull.
I know Pink Triangle is defunct, or at least I think I know; but there is a good following. Have you tried posting on one of the specialty group sites such as Yahoo?
Previous Topic: Sansui Turntable - Cartridge?
Next Topic: How Often Do YOU Lube platter shaft / motor?
Current Time: Fri Nov 06 00:16:39 CST 2026
