Home » Audio » Source » soliciting turntable purchase and record care advice
Re: soliciting turntable purchase and record care advice [message #11914 is a reply to message #11913] Wed, 09 February 2005 07:32 Go to previous messageGo to previous message
Cooper338 is currently offline  Cooper338
Crimedawg:
I like the Audio Technica AT-PL120 turntable ($220, incl. shipping)that I purchased recently off of eBay. It has a line-out/preamp switch which allows you to hook the turntable up directly to a computer in case you plan to do any transfers to CD. However, I'm planning to replace the supplied cartridge with a Shure M97xE ($70). If you plan on playing 78s, you could also purchase a Shure M78s cartridge, which is made specifically for that purpose ($40). That leaves you about $170 for cleaning supplies and accessories. Maybe you could even get lucky and find a used Nitty Gritty Cleaning Machine on eBay.
It sure is fun spending other people's money!
Coop
Previous Topic: Old Dual with motor problems
Next Topic: BSR help
Current Time: Thu Nov 05 22:02:36 CST 2026
