Home » Audio » Source » Tracking Force
Re: Tracking Force [message #11893 is a reply to message #11890] Thu, 03 February 2005 13:23 Go to previous messageGo to previous message
Wayne's thread is informative, the short answer is don't worry. The difference between a cartridge that tracks at 2 and 3 grams is negligable. And that arm you are probably better off tracking at the high end. If the cartridge calls for a range between 2 and 3; track at 3. When the needle is firmly seated in the groove There will be less wear over all. How many times do you plan on playing each individual record? Also; how difficult are they to replace, that is the real question. I track my rare Blue Note jazz albums at 2.4 grams and they are holding up fine.
If you have rare recordings then you need to examine the whole objective of the table/arm/cart system. Otherwize I wouldn't obcess.
Previous Topic: My latest AR Mod/platter mat
Next Topic: HELP! my counterweight broke off
Current Time: Sun Oct 25 19:59:22 CDT 2026
