Home » Audio » Source » Turntable thrust bearing (replacement) alternative
Re: Turntable thrust bearing (replacement) alternative [message #11880 is a reply to message #11729] Mon, 31 January 2005 20:32 Go to previous messageGo to previous message
dwebb is currently offline  dwebb
Sounds like an elegant solution. I have the same issue with the five balls being MIA from the thrust bearing. Do you by chance have the dimensions of the Teflon disks you made? Also, the phenolic bearing race seems to be captured beneath the Cam assembly. Did you have to remove this cam assembly to get access to slide the bearing race up the spindle?
Previous Topic: Do I need a Phono pre-amp box???
Next Topic: Systemdek 2 bearing
Current Time: Fri Nov 06 00:16:14 CST 2026
