Home » Audio » Source » need some help
Re: "A Bridge Too Far" [message #11871 is a reply to message #11870] Fri, 28 January 2005 03:23 Go to previous message
Great looking! Love that 70's Mediteranean Red Velvet!
You'll need to remove the turntable to get underneath. I'm pretty sure the platter is held by a circlip but you can try lifting up on it evenly on both sides and see if it comes out of the bearing well.Don't use too much force but keep upward for a while. Once out see if there is a small rubber wheel (idler wheel)turning the platter or a belt and if the motor is turning. It might be as simple as putting the belt back on the pulley. Or buying a replacement belt or idler wheel.
Parts
Previous Topic: digital to digital converter ?
Next Topic: The Answer is "Marvin the Martian Slippers"
Current Time: Thu Nov 05 23:21:54 CST 2026
