Home » Audio » Source » turntable troubles...
Re: turntable troubles... [message #11862 is a reply to message #11860] Mon, 24 January 2005 16:40 Go to previous messageGo to previous message
Try to isolate your problem with a process of elimination. First, swap the entire turntable with another, if that's possible. This will let you know if the problem is in the turntable or the (pre)amp. If the problem is the turntable, then swap the cartridge. If the problem persists, then your wires may have moved back and forth somewhere and opened up. Or maybe a connection has oxidized.
Previous Topic: Turntable problems
Next Topic: digital to digital converter ?
Current Time: Mon Sep 21 22:57:29 CDT 2026
