Home » Audio » Source » Tone arm lift pad
Re: Tone arm lift pad [message #11809 is a reply to message #11806] Sun, 02 January 2005 17:37 Go to previous messageGo to previous message
Try Sutherlands or Lowes. You can buy rubber sheets with adhesive on one side and that might work for you. What I'm thinking of here is the same kind of stuff used for rubber feet on little cabinets like you'd buy at Radio Shack. Now that I think about it, Radio Shack might also have small adhesive rubber sheets. Just cut a little to fit.
Previous Topic: My Project 1.2 has difficulty getting started
Next Topic: WWW.Bestmp3guide.com
Current Time: Wed Oct 21 11:55:25 CDT 2026
