Home » Audio » Source » Delrin arm board for AR turntable
Re: Delrin arm board for AR turntable [message #11787 is a reply to message #11786] Wed, 15 December 2004 17:36 Go to previous messageGo to previous message
Thats great to hear, i would be interested, if for no other reason my black widows instuction manual shows a 103 mounted on it. I didn't realize you had a 103. Can you tell mw about its characteristic sound as compared to some of the other carts you have experience with? I assume its weight/mass and compliance are correct for my arm. Unless the photographer just bolted on the nearest cart. My arm will use carts with weights from 4 to 8.5 grams. I am looking for a signifigant step up from my ortofon OM 30. Do you think it would be?
Regards, Russellc
Previous Topic: Best Vinyl Disc Cleaning Method
Next Topic: Update on Tascam unit in the previous post.
Current Time: Wed Oct 21 18:45:34 CDT 2026
