Home » Audio » Source » Actual bias vs set bias/antiskate
Re: Actual bias vs set bias/antiskate [message #11757 is a reply to message #11756] Sun, 05 December 2004 12:29 Go to previous messageGo to previous message
Yes, his name is Anthony Scillia and you can see some of his work as well as contact info at: www.theanalogdept.com/anthony_scillia.htm
You can see a little more of his work in the AR gallery on the vinyle nirvana site. Anthony has told me that as soon as the Merrill Audio site is revamped, he will have info there as well. So far I plan on using his delrin armboard and stud kit that allows the use of linn springs and lower grommets, and improved lock nuts of some sort. His merrill redo of the acrylic outer platter is supposed to be ready shortly, and that will be combined with the delrin inner platter , along with a much improved stainless shaft which is available with or without threads for screww on clamp, which he also makes. The outer platter is also to be used with the merrill lead mat, which is also being redone. He has future plans to make the motor available like merrill used to sell, and I think I remember him saying that the delrin pully is also available. I hope that he redoes the sub chassis, said it was being explored, but no commitment yet. He did tell me that the merril perifery clamp was not in the plans, but I see VPI offers one, and since albums are the same size, I assume it would fit?
Regards, Russellc
Previous Topic: Turntable for less than $300?
Next Topic: Transistors/ cross referencing
Current Time: Thu Nov 19 07:20:36 CST 2026
