Home » Audio » Source » Cartridge Tracking Force
Re: Cartridge Tracking Force [message #11742 is a reply to message #11741] Sat, 27 November 2004 08:12 Go to previous messageGo to previous message
Yes; while you are making these adjustments I would suggest using a record that you will not miss if there is a bad tracking error. Also I did not mention that you cannot always trust the setting on the tonearm. They can be off by a little so I would purchase a shure tracking force indicator. It is a see-saw type device that is very accurate at measuring the tracking force and costs about 10$. good luck. BTW did you say which table you have? I looked the cartridge up you have and they call for between 1.8-2.2 grams tracking force. I would stay with the 2 gram unless you hear it lock in at a lower setting. J.R.
Previous Topic: Boston Acoustics Cartridge - replacement stylus??
Next Topic: Turntable worries
Current Time: Thu Nov 19 12:51:36 CST 2026
