Home » Audio » Source » Direct Drive Revisited
Re: Direct Drive Revisited [message #11670 is a reply to message #11669] Mon, 19 July 2004 16:59 Go to previous messageGo to previous message
It really is a lot like pushrods and overhead cams to me. I think the analogy works well. Just like engines with pushrods and overhead cams, turntables with belts and those with direct drive each have design strengths and weaknesses.
Some of the best engines use pushrods, and custom buiders of both Harley's and automotive V-8's use 'em. I can't tell you how much technology there is available for this kind of application. If you want to build the best custom Harley in the world, you're probably going to use an engine with pushrods. It will be really cool and provide stomping power. It will turn every head. You can solve every technical hurdle so that you exploit the strengths of the engine while reducing its weaknesses. But that doesn't mean overhead cams are inferior by design. It's the specific implementation that's great.
Previous Topic: AR Dust cover needed
Next Topic: Alignment FAQ
Current Time: Thu Nov 05 05:29:25 CST 2026
