Home » Audio » Source » AR Pulley
AR Pulley [message #11649] Tue, 22 June 2004 16:09 Go to previous message
martinleewin is currently offline  martinleewin
I got a The AR Turntable (XE) that apparently someone did a halfway 240volt 50 Hz conversion. The decal says 240v and the motor is 110v 60 Hz. And it runs about 40 rpm on the low speed. . . deducing it still has the larger 50 Hz pulley. . . shaft is .125, 33 rpm size is .984, 45 is 1.339 inch diameter.
Do you have any 60 Hz pulleys for this guy? Are they the same as an XA or XB? They all look similar.
Previous Topic: Dual 505 repair questions
Next Topic: AR XA TT
Current Time: Thu Nov 05 12:26:09 CST 2026
