Home » Audio » General » AC/DC Electronics
Re: AC/DC Electronics [message #1163 is a reply to message #1161] Sat, 18 December 2004 00:17 Go to previous messageGo to previous message
Instead of having an AC signal with zero crossing at 0 volts, shift it to whatever the DC level is. That is a description of an AC signal riding on a DC one.
If you think about it, there is always a DC component. Whatever the zero crossing average is, that's the DC value. If it is exactly the same as your reference, then you might consider it to have no DC component, or zero volts. But if you reference it to something else, there may be some DC offset.
Previous Topic: P.C. Audio
Next Topic: is this wayneparham.com?
Current Time: Sat Sep 26 09:54:59 CDT 2026
