Home » Audio » Source » Spinning slow
Re: Spinning slow [message #11596 is a reply to message #11595] Wed, 05 May 2004 13:01 Go to previous messageGo to previous message
Larry is currently offline  Larry
the problem may be the belt. it may also be a defective motor or something in the electronics. this model uses a motor drive ic as well as a couple of transistors to switch and adjust the two speeds. check the belt, if that's not the problem, you can send it in for repair.
Previous Topic: Ah, nostalgia! It used to be simple
Next Topic: Major Vinyl score today
Current Time: Wed Nov 04 15:48:28 CST 2026
