Home » Audio » Source » AR XB1 wire ring mod?
Re: AR XB1 wire ring mod? [message #11546 is a reply to message #11544] Sat, 27 March 2004 22:46 Go to previous message
Howard is currently offline  Howard
Dear John,
Thanks for the information. I will get in touch with Tim shortly.
I am interested in any mods you are willing to pass on.
I have spent time listening to the XB1. It is nice sounding in soft way. Nothing to worry about, but it lacks a bit of bite. Particularly in the bottom end. I was using a VFET amp (known for bass) and a couple of Pioneer CS911s (with 15in bass drivers) and alnico tweeters.
The plinth is actually not bad. I will probably keep it as is. The deck really isolates external vibration. The 1967 advert is right you can strike the top plate with no effect on playing
Thanks again
Howard
Previous Topic: Another site with some good TT tweaks
Next Topic: AR needle force gauge
Current Time: Tue Nov 03 10:19:57 CST 2026
