Home » Audio » Source » Pre-amp
Re: Pre-amp [message #11532 is a reply to message #11494] Fri, 12 March 2004 15:14 Go to previous message
Oldtechie is currently offline  Oldtechie
Just a note, whenever you hook a magnetic cartridge turntable up to a reciever you will need a Phono pre-amp, the ceramic needle output don't require one, the magnetic cartridges output is so low you need an "amp" to be able to pre-boost the signal before going into the line level inputs of a reciever.
The trick is in getting a "clean" amp to boost the signal, a low noise to signal ratio. I use an A/C type and even with isolation you still can detect a slight 60 hz a/c hum in the background, it is very low but still it is there. So I would imagine that your battery powered one would be the best choice:)
There is tons of techincal jargon related to this subject but this is the basic facts, 30+ years servicing these products professionally and learning from others has helped me, I hope this helps you:):)
Previous Topic: Non-oversampled 16 bit DAC
Next Topic: Best and Worst labels for classical vinyl?
Current Time: Fri Nov 06 01:29:40 CST 2026
