Home » Audio » Thermionic Emissions » 1st Scratch Build Done.
Re: 1st Scratch Build Done. [message #11453 is a reply to message #11438] Thu, 26 February 2009 00:25 Go to previous messageGo to previous message
Norbert is currently offline  Norbert
Shane,
I thoroughly enjoyed viewing your build. I recently build a 300B SET based on "Legacy" C3M penthode input stage. Couple of suggestions you may want to look into to improve the sound.
1] add ultrapath stage. The best source to find out more is from www.tubecad.com site
2] not sure if heard any arching from your power switch when turning it on/off,if that is the case consider adding 0.1uF@400V+ film cap across the switch
3] experiment with 2uF film cap across both cathode caps
Cheers,
Norbert
Previous Topic: Darling amp done
Next Topic: amp questions
Current Time: Mon Nov 23 01:00:54 CST 2026
