Home » Audio » Thermionic Emissions » Hybrid SET question
Re: Hybrid SET question [message #11381 is a reply to message #11378] Thu, 19 July 2007 06:57 Go to previous message
I'm thinking that the max rail voltages of +/- 17v might limit you to easy tubes like EL84,EL34. Otherwise you might need an additional gain stage. The swing needed for a 300b is pretty healthy, and an 845 much more so. Still, no reason it couldn't be used as a 1st stage in a 3 stage design. I'm not any kind of expert on this, so maybe someone else will chime in.
Previous Topic: Tweaking the ARC LS-1
Next Topic: fender hot rod series combo amp ques.
Current Time: Fri Oct 23 08:36:41 CDT 2026
