Home » Audio » Thermionic Emissions » Boy, is this a dull forum...
Re: Old dog learned a new trick [message #11362 is a reply to message #11351] Mon, 04 December 2006 06:38 Go to previous messageGo to previous message
Fried a resistor on the driver stage of the 45 amp the other day.
Bad driver tube took it out. Or bad CCS mosfet took out the tube, or...
Have had a problem with the turn-on surge of the B+. Even damaged the other channels mosfet.
In looking over the problem and replacing the bad parts at the WSOTT meeting Saturday, Steve suggested implementing a switch on the B+. With a .01uF 2kV cap across the terminals.
Last night I installed it. On the center tap connection to ground.
Just a SPST 250 VAC, 10 amp rated toggle.
Powered up and let the filaments warm up for a few minutes, then closed the switch. No flashes or crackles, which I had previously.
Previous Topic: Melos Mat 185 schematic or repair needed
Next Topic: Oh my, what a big toob you have!
Current Time: Fri Oct 23 08:36:37 CDT 2026
