Home » Audio » Thermionic Emissions » 6Ah4 Amp
Re: 6Ah4 Amp [message #11341 is a reply to message #11340] Wed, 19 July 2006 17:27 Go to previous messageGo to previous message
Hey-Hey!!!,
There is nothing stupid about the points you've made...or the questions you ask. If there were one single best, most of us would probably build it.
Building something that is a bit different, and inovative is a lot of what makes this fun. Just because the general population hasn't recognized something as good, does not mean it's not. Perhaps even excellent, yes?.
The Galahad schematic is still on my build list. I figured a way to combine my next two amps into one convertible just so I could do some more varied building. I don't think I would change anything about it. One of the attractions of the pentode front end is its nearly constant output Z with signal level. The plate Z can chage a lot, and the whole thing will still be dominated by the plate load resistor. That's probably a good thing...:)
I do suspect that part of the multitude of 2A3 amps is due to the value of personal experimentation. I know you can relate with the "I'll build it myself and see" mentality. Probably also because it work well too.
cheers,
Douglas
Previous Topic: Marshall DSL100 Buzz
Next Topic: Seduction done!
Current Time: Fri Nov 27 12:35:52 CST 2026
