Home » Audio » Thermionic Emissions » Can Someone suggest a good book on S.E.T.'s.
Re: and then... [message #11307 is a reply to message #11306] Thu, 16 March 2006 06:51 Go to previous messageGo to previous message
The hardest thing in teaching something as complex as electronics to newbies through a forum like this is to find the fundamental connections between what they understand and what they are looking to find out.
Example; OPT primary winding resistance. You look at catalogues of transformers and mostly you se a few standard values; 5k/3.5k/8k/10k/ and rarely 12or 14k. Once in a while 7.5k. Now if those are the standard values and each one is somehow most applicable to one set of RP values then a begginner says hey whats the fuss, you already know what value you need as soon as you pick your tube for the output.
Then loadlines; all that seems to have been done for you by many charts and experiments; just follow the yellow brick road and voila'.
But I know it's not that simple when you are struggling to come up with a better set of values to co-respond with a goal you have regarding a rarely used tube or a different and not so common circuit.
Previous Topic: How long do EH ff 300b's last
Next Topic: Has anyone used the 6CK4 as an output tube?
Current Time: Wed Nov 04 21:31:19 CST 2026
