Home » Audio » Thermionic Emissions » Ping: Speakerman57
Re: speaker part [message #11245 is a reply to message #11242] Fri, 28 October 2005 20:39 Go to previous messageGo to previous message
PeterP is currently offline  PeterP
Douglas,
"Mids: Fostex FE107, horn loaded with 18" axial length, 30-degree included and a 2" throat."
I just finished a little 6L dual port FE107E. Right now I'm using it full range as an office system. I was wondering as to what crossover points are you using your horn? I really like the mid-range of this speaker.
When used in your system as a horn loaded mid, is it capable of "party" levels? There is just too much break-up when playing high volume levels at full range for me to tell if it's worth putting this driver into my main system.
Is the:
"Bass: JBL 4560 cabs loaded with EVM-15L EV's " the same ones that you had in MD?
Regards,
Pete.
Previous Topic: Anyone tried other op points in Guinevere?
Next Topic: Need power supply schematic for Merlin amplifier?
Current Time: Fri Oct 30 21:14:54 CDT 2026
