Home » Audio » Thermionic Emissions » Looking for good 20 watt amp design to drive Jordan TL's?
Re: Damping factor - SE vs. PP [message #11223 is a reply to message #11220] Wed, 12 October 2005 13:47 Go to previous messageGo to previous message
Steve is currently offline  Steve
I have to disagree a little. (assume no global feedback). Viewed near the operating point with minimal signal swing, there isn't much difference.
But as the signal swings more and more, the DF varies more and more in an SET than a PP amp as the Ra is changing more in an SET triode while the PP triode combo is more constant. Theoretically, as one triode's Ra is rising, the other is lowering, maintaining an approx constant.
This Ra swing occurs in all triodes, with the Ra varying from several hundred ohms to thousands of ohms and eventually (theoretically) infinite ohms at triode cutoff.
Previous Topic: Polarized non-polar caps
Next Topic: Need 15 watt plus SET design for DIY?
Current Time: Fri Nov 27 18:03:17 CST 2026
