Home » Audio » Thermionic Emissions » Help with '45' problem?
Seems simple enough... [message #11202 is a reply to message #11192] Wed, 31 August 2005 16:19 Go to previous messageGo to previous message
Thrint is currently offline  Thrint
the obvious answer is that the SE45 does not have enough power for your app.
The more helpful idea would be to suggest an exhaustive look into where is the overload taking place? You can go so far as to seperate stages, but this might not give a clear picture if there is stage-stage interaction in the PS.
If you it is an open loop, or short loop NFB amp you ought to be able to proceed from the input stage to the final and see some evidence of overlaod/clipping. Be thorough, and ask questions as required.
cheers,
Douglas
Previous Topic: SET amps that will only rock Septeguenarians
Next Topic: One output transformer hotter than the other
Current Time: Wed Nov 04 21:22:09 CST 2026
