Home » Audio » Thermionic Emissions » Help with '45' problem?
Re: Help with '45' problem? [message #11193 is a reply to message #11192] Thu, 18 August 2005 08:29 Go to previous messageGo to previous message
What's the input impedance of that amp? I wonder if it's a bit low for that CD player.
Another thing I've seen a lot is mechanical connections causing those symptoms. They can almost seem like magic too; You'd think they'd be consistent but they're not. If the junction makes contact but poorly, it's an intermittent connection with highly changing resistance. Places it can develop are volume pots, switches and tube sockets.
Then there's those weird Valve Art tubes. Remember them on the Paramours? More magic. Sound great when running, but like Geiger counters when idle. Sometimes. And only every other tube does it, some sound great. Don't guess that's what's up with your amp, but I thought it worth mentioning. 'Spose it could be something like that.
Those are some of the things I'd look at.
Previous Topic: SET amps that will only rock Septeguenarians
Next Topic: One output transformer hotter than the other
Current Time: Sat Oct 17 15:22:11 CDT 2026
