Home » Audio » Thermionic Emissions » SE for beginners
Re: for beginners [message #11033 is a reply to message #11032] Wed, 02 March 2005 17:58 Go to previous messageGo to previous message
Howard is currently offline  Howard
Dear Douglas,
Thanks for your response. I have built some solid state amps. I would be a bit nervous about all that high voltage. (Although 240V is enough to do serious damage if you have sweaty hands)
Getting power supply bits may be a problem locally. If you could advise on a source it all sounds fine to me.
With my speakers I would probably go with the SE variant
Thanks again
Howard
Previous Topic: What a difference a capacitor change can make!
Next Topic: It's finally being printed!
Current Time: Sat Nov 21 05:21:01 CST 2026
