Home » Audio » Thermionic Emissions » Pull pin...
"Budget" SET=Milatary Intelligence [message #10992 is a reply to message #10990] Tue, 15 February 2005 18:01 Go to previous messageGo to previous message
existing only on paper...
SET is not like PP in a few ways. One is the means of dealing with the idle current. The 45, 2A3 and 300B can all run on a plate load of 4k. Idle current differs by a factor of two.
Minimum primary L requirement at power is still the same, yet one will have to deal with twice the DC. With PP, if the a-a load is right, and you don't overheat things with too much idle DC, you'll be fine if you can keep the two halves balanced.
regards,
Douglas
Previous Topic: Budget Amp
Next Topic: Tweaker "universal" mono amps
Current Time: Thu Nov 05 22:09:58 CST 2026
