Home » Audio » Thermionic Emissions » Pull pin...
Re: Pull pin... [message #10963 is a reply to message #10960] Mon, 14 February 2005 12:48 Go to previous messageGo to previous message
TC,
Thank you for your advice on further study. We could ALL do with more study, especially the less technical amongst us who have no idea about engineering of any sort.
For your benefit, please read the statement below:
"Amp designs with push-pull or balanced topologies can achieve lower overall levels of distortion than single ended amps. On the other hand, they achieve this overall distortion reduction chiefly by canceling out even order (2nd, 4th, etc.) distortion byproducts, which leaves behind a disproportionate share of odd order (3rd, 5th, etc.) distortion byproducts. "
Taken from:
http://www.iar-80.com/page2.html
Hope this helps you. My advice would be to read that entire page, it would be well worth your while.
thanx
-akhilesh
Previous Topic: Budget Amp
Next Topic: Tweaker "universal" mono amps
Current Time: Fri Nov 27 12:59:37 CST 2026
