Home » Audio » Thermionic Emissions » Chinese audio
Re: Chinese audio [message #10702 is a reply to message #10699] Wed, 25 August 2004 07:44 Go to previous message
Colin; have you ever peeked inside and noticed if any of the passive parts are recognisable brands? Just curious whether caps and resistors are sourced through common producers. There is a case to be made that if the amp sounds good then the parts should be decent quality. Because if they are not then what does that say about the use of boutique parts in amplifiers and such if you can build a good sounding amp with poor quality parts.
That leaves the transformers; I could assume they might fail at some point if they are not constructed properly, but many of the Chinese brands have been around for some time and have a good track record. And again if they work and sound good they must by definition be decently made.
However Chinese tubes have a spotty history of reliability, but those are the most difficult parts to construct.
A few thoughts, J.R.(I have had some of the newer western tubes fail out of the box so who knows?)
Previous Topic: ping gumby1
Next Topic: 47 tube
Current Time: Thu Nov 05 12:57:51 CST 2026
