Home » Audio » Thermionic Emissions » SET 45
417A>45 SET in the works [message #10648 is a reply to message #10642] Thu, 15 July 2004 06:51 Go to previous messageGo to previous message
billfort is currently offline  billfort
Well, this is encouraging akhilesh! I’m currently building a 45 SET and had some reservations as to whether I’d be happy with the low power on my 100db eff. Altec 604’s. I may end up trying the 45 in a bi-amp configuration with my existing 300B SET on the 15” Altec woofers, I really like the bass with this combination.
The amp I’m building is VERY similar to yours – 417A driver, cap coupled (Jupiter beeswax), all James iron, Blackgate and Elna Cerafine caps, Mills, Riken, Tantalum and Caddock resistors, WE copper wire and Cardas unplated copper binding posts. All tubes will have AC heat but I’ll use humpots on the 45’s as I hear this adds more flexibility for tube swapping. The chassis will be punched stainless steel and SA Mahogany, similar to my first DIY 300B SET. So far I’ve rounded up Western and Northern Electric 417A, Raytheon 5842 and ST 45, RCA UX245 and a few NOS 5U4G and GT rectifier tubes to try. I’ve added Riken shunted ALPS blue velvet level pots for each channel so I can use these to attenuate the 604 horns when trying passive line-level crossovers. I’ll post a picture when I get a little further along on assembly.
Bill
Previous Topic: Tube Pre-Amp Recommendation
Next Topic: Metasonix TM-4
Current Time: Thu Nov 19 13:06:38 CST 2026
