Home » Audio » Thermionic Emissions » Ultimate single ended Triode amp
Re: Ultimate single ended Triode amp [message #10560 is a reply to message #10558] Fri, 05 March 2004 09:44 Go to previous messageGo to previous message
Phil Wilson is currently offline  Phil Wilson
I am interested in people's thoughts on this as well. I also have a Zen (the Select version, which is the same circuit and tubes as Akhilesh's). I also love my amp but I have noticed in my limited listening experience that the higher-powered tube amps (like Akhilesh's kit from S-5 Electonics and Mark Margiotta's Music Reference - both push-pulls - and even the Paramour's) seem to have more authority in the lower frequencies, even on the single driver speakers Akhilesh and I own. I haven't had enough A/B listening to identify what you lose with this (if anything) but it is something I've noticed. Since I want to build an amp sometime, I will probably do a higher-powered version when I do it (probably a kit, but someday I'd like to do one from scratch).
Also, from what I read, it sounds like other than the tube you choose that the power transformers are the key upgrades to make the "ultimate" amp. What transformers do people think are the best?
Previous Topic: ASL Si15-DT
Next Topic: Single-Ended Bits
Current Time: Thu Nov 26 18:21:03 CST 2026
