Home » Audio » General » Adding to the system!
Re: Adding to the system! [message #1055 is a reply to message #1052] Sun, 31 October 2004 20:05 Go to previous messageGo to previous message
Bob Soden is currently offline  Bob Soden
Manual? I hope that is you name... No I have made these purchases so far,
the VPI HW-19 JR
Audio QUest PT9 Arm
Grado Reference platinum
Probably could get a better cartridge, but do no know which to get, so I have ordered this one, do you think it is a good choice?
Sounds like you are experienced, so may I ask a question , is the VPI already drilled for the Arm? IN the pic it appears so, and the arm apppears to be coming with its own table as well.
Yes, and I can use all the help I can get, I would appreaciate your help.
bob
Previous Topic: Sherri; Whats the scoop betty boop?
Next Topic: Halloween
Current Time: Fri Oct 16 11:09:34 CDT 2026
