Home » Audio » Thermionic Emissions » Moondog's need new tubes
Re: Moondog's need new tubes [message #10533 is a reply to message #10531] Fri, 13 February 2004 00:11 Go to previous messageGo to previous message
Wow, I can't believe Valve Art has such a high failure rate on their 2A3 tubes. I'd consider this noise to be a failure mode. I suppose it might be related to method of use, operating point or circuit configuration, but both you and I are getting the same symptoms.
What amp(s) and circuit configuration(s) are you running them in? I've got 'em in stock Paramours, and the symptom follows the tube. What I mean is that I can swap the tubes between amps and the symptom follows the tube, not the amp.
Previous Topic: This may be interesting to some
Next Topic: ZEN Se-84C...anyone compared it to other SETs?
Current Time: Wed Nov 04 00:15:21 CST 2026
