Home » Audio » Thermionic Emissions » OK lets try this one: any Schematic for an amp...
OK lets try this one: any Schematic for an amp... [message #10509] Wed, 14 January 2004 22:14
...that is simple to build using 300B Op points/ transformers, etc but with commonly available and inexpensive tubes and sounds as good as the venerable "B"? I want to build an amp from scratch that sounds better than my good sounding Paramours but can't afford the designer tubes for the present. I could conceivably swap out the TFA 2004s and BCP 15s from the Paramours. Any ideas?
Thanks!
Garland
Previous Topic: Nowadays you listen to SET. What path lead you here?
Next Topic: cheap kits for tube amps
Current Time: Mon Oct 26 18:25:24 CDT 2026
