Home » Audio » Silicon Valley » Very Good Construction article
Re: Very Good Construction article [message #10418 is a reply to message #10417] Mon, 06 March 2006 08:08 Go to previous messageGo to previous message
MB,
Does the $90 include powersupply? If so, that's a great deal.
Marchand's prices aren't pricey. I just looked at ESP's pricing for boards and they're in the same ballpark ($20-$30). What I can say is that Marchand's boards are very high quality. Thick and rigid, double-side and teflon coated. The brackets and heatsinks you can order with his amp boards are drilled and tapped to fit the boards perfectly.
Marchand's version of the GC (PM21) is available as a stereo board for just $20. $100 gets you all the parts and the board. Sounds a bit pricey, but the design gives you the flexibility to run the amp with inverting, non-inverting, or differential inputs after it's been assembled. You can also get a power supply unit that includes a 160VA toriodal with 20,000uF per rail for another $100.
I know this sounds like a commerical for Phil, but I think his stuff has been overlooked and underrated.
g.
Previous Topic: Tandberg TR-2080
Next Topic: What does Yamaha use
Current Time: Tue Nov 24 02:05:27 CST 2026
