Home » Audio » General » THD Definitions
Yes [message #1029 is a reply to message #1025] Mon, 25 October 2004 20:07 Go to previous message
Klippel suggested a scheme which increased the values of distortion as frequency rises- i found it on a google search
(dont forget to use the advanced search function to search sites individually)
Also of note is not just a % figure overall-but how it varies with frequency on transducers,and how class A/b amps although measuring well can have HF artifacts,and class A reduce distortion with lower level more like Valve amps(but are only similar in that respect)
Im planning on a 3.1 way active system with Class A eventually
Cheers!
Previous Topic: Found Some Resource for Active Crossover Design
Next Topic: Heard a String Trio
Current Time: Thu Nov 26 19:21:19 CST 2026
