Home » Audio » Silicon Valley » LM3875
Re: National Semiconductor Amp Modules [message #10208 is a reply to message #10206] Tue, 21 September 2004 21:19 Go to previous messageGo to previous message
I agree about the regulation. The supply for a powerful amp should have adequate current capacity and should be regulated so that the voltage rails don't fluctuate with changes in current demand.
I understand how some tube amp enthusiasts like using a simple unregulated circuit, but I think this is more for simplicity's sake than anything else. If there is not much of a current demand, then that's sufficient. Small power tube amps are that way.
But high power needs higher current, and the swings can really rob a power supply. So in this case, I think a good, high-current regulated supply is important. You could even do something like using motorcycle batteries or small sealed lead-acid batteries for improved transient current capacity.
Previous Topic: DIY amp kits
Next Topic: I wish there had been more to fix!
Current Time: Mon Oct 05 07:41:39 CDT 2026
